Oil Burner stops mid-burn
plazo
Member Posts: 4
in Oil Heating
(I probably posted this originally in the wrong forum)
I had trouble with my oiler burner at the end of last year - the reset button on the controller kept opening. Over the summer, I replaced the oil filter and pump screen, happy that it ran trouble free for a month already this season. But it’s happening again… Burner always starts up great when the reset is pushed - seems no problem with transformer, cad cell or electrodes?
I sat with it this time - no puff-back or unburned fuel odor .. It sounded like a good, normal burn for 10 minutes until the reset button popped out for no apparent reason and shut boiler down.
What would cause a burn to be stopped like that - in the middle of a normal burn? I thought the primary control/cad cell only operated to verify initial ignition…could the primary be faulty?
Help and insight are appreciated!
The relay and eye are checking throughout the burners running time .. If the eye does not have an clear line of sight , faulty or loose in its holder it will drop out the relay ... At 1300ohm + - the relay starts dropping out ... Best to stay around 500-800 ohm
- 128 Chimneys & Flues
