Clearance, nfpa 31
RLuck
Member Posts: 24
A manual says 6 in clearance back and sides or to nfpa 31 latest edition. It's a real tight spot and I need every inch. What are the standards for nfpa 31 ? It's an oil boiler with sheetrock walls. Thanks can't find an answer elsewhere.
Make sure the inspector will see perfectly sealed and taped drywall with this, as most inspectors here (Nebraska), can make their own judgements on clearance to combustibles during the inspection.—NBC0
But does npfa 31 allow for say sheet metal on the walls and 2 inches clearance, instead of manufacturer's 6 inch spec?0
the only way to know is ask your local inspector what they recommend, they are the ones signing off, so word to the wise do what they want, but like nicholas said, every inspector can make a judgment call, hopefully your inspector has that,lol"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0
