Need special ball valve for steam, or regular brass ball valve?
Motorapido
Member Posts: 314
I plan to install a ball valve shut off under the 0 to 16 ounce gauge that I am adding to my boiler, and need to know if I can use a regular old brass-bodied 1/4 inch NPT plumbing ball valve or if I need something special for steam applications. Please educate me. Thanks.
Rated for at least 200* if its after the steam syphon. I prefer a teflon seal.0
Most would us a regular ball valve but there are ball valves rated for steam use which is what should be used.
Cheap valve may not have a steam rating0 -
I used these for what you're looking to do (see pic). The pdf sheet shows the pressure and temp ratings. Supplyhouse carries them for short money.0
The Webstone 4168 above is rated 125# steam. Your good to go!0
