Easily Confused
HeatingHelp
Administrator Posts: 703
Easily Confused
Words can confuse people, especially when talking about hydronic heating.
Unfortunately, yes. I am rather confused...
Above, you start by talking about velocity, and mention 4 fpm. Using that as a starting point, I presume that you are going to hold that constant, and talk about how the GPM will RISE as the size of the pipe increases. Instead you try to convince us that the "GPM will slow down", which is not correct if you are holding the velocity constant. For the same velocity, a larger pipe will be moving much more GPM than the smaller one. If you hold the GPM constant (which is much closer to the way things would work in most situations), then the velocity would "slow down" as you go from the smaller pipe to the larger one, which is what I think you were trying to get at, but somehow you got it confused :-(
-Phil0 -
I am hoping that response is tongue in cheek.0
Sorry for the confusion, Phil. Here's what I said:
Velocity is about a certain amount of distance (let say feet) and a fixed amount of time (one second). Suppose water is moving at four feet per second. You can see that in your imagination, right? But how many gallons are we talking about here? We didn't say anything about GPM. We're talking about speed right now, and that brings us to pipe size. If the pipe is, say, 3/4-inch, the GPM will be a certain number, but if the pipe is two-inch, the GPM will slow down. It's still the same amount of water and the same amount of time. It's just going slower because it's on a wider road. That's velocity.
Here's what I meant: Let's say we have a controlled flow of 4 GPM in a 3/4" copper pipe. It moves at 2.5 feet per second. That same controlled flow rate in a 1" pipe will move at 1.5 feet per second. It's going slower now, but it's still 4 GPM. I suppose I should have used a different term than GPM. I'm thinking in pictures. I'm seeing a wide, slow-moving river funneling into a narrow, fast-moving rapids.
Your turn. Thanks.Retired and loving it.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 966 Plumbing
- 6.3K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 44 Industry Classes
