Vent & Cover
New England SteamWorks
Member Posts: 1,529
Best course of action to save big bucks quick. Don't get caught with naked pipes that can't vent quickly or you'll pay and pay...
This customer saw the light and now his system is purring quietly and just sipping fuel.
Nice:
newenglandsteamworks.com
It's amazing the difference that makes.
I just got all of the materials to complete my header insulation , this thread is almost motivating me go down and finish it.hvacfreak
Mechanical Enthusiast
Burnham MST 396 , 60 oz gauge , Tigerloop , Firomatic Check Valve , Mcdonnell Miller 67 lwco , Danfoss RA2k TRV'sEasyio FG20 Controller
Almost?
Got you covered:
newenglandsteamworks.com2 -
Ha ha, that might just do it. I did the straight sections last week and I now have the fittings and pvc jacket. Time consuming and tedious . I noticed a huge difference just doing what I did , the system piping is insulated and I didn't think the header would matter much but I was wrong on that.hvacfreak
Thank you. Can't tell you how often this topic comes up and I have seen too many times first-hand how much a difference it makes to insulate not just the pipes, but the fittings and the near boiler piping. And yet, folks continue to try and make a case that it is unimportant...hvacfreak2 said:I noticed a huge difference just doing what I did , the system piping is insulated and I didn't think the header would matter much but I was wrong on that.
newenglandsteamworks.com0 -
That's not engineered properly. Pulling the cord will send the boot in the wrong direction.New England SteamWorks said:Almost?
Got you covered:
Beautiful on the installation of the insulation.There was an error rendering this rich post.
2 -
Ha! Right! It'll kick him in the head!New England SteamWorks
newenglandsteamworks.com1 -
Id like to insulate my pipes on a steam system. Can you recommend a good supplier (online preferable)? I am based in the philadelphia area. This is my third heating season and trying to reduce my nat gas bill.
Thanks!0 -
The source listed above is in NY. For us in MA/RI the shipping is not bad at all, and the OP is in PA, so he should be fine as well.
But otherwise I agree. It's not the length however. My understanding is there is a special shipping rate for things like insulation and foam that are relatively large, but light-weight. These type of parcels don't get billed by weight, but cube or some such.New England SteamWorks
I've used them and it was affordable. I'm in Michigan. I did about half my system that way. I'd recommend you purchase it all at once instead of small little buys so they can pack the boxes with as much stuff as possible.
I'd prefer to buy locally, but, as a homeowner with a day job, sometimes its difficult to get to supply stores during business hours without taking time off. Life is full of trade-offs.Burnham IN5PVNI Boiler, Single Pipe with 290 EDR
18 Ounce per Square Inch Gauge
Time Delay Relay in Series with Thermostat
Operating Pressure 0.3-0.5 Ounce per Square Inch0 -
I worked as a technician for USPS for 8 years. Larger packages that don't weigh much have to be sorted by hand and they charge more for that.
Most parcels are sorted on a machine that is several hundred feet long and looks like an elevated race track each parcel sits on a 18"(?) square pad. A camera finds and reads the address and that square pad tilts and dumps the parcel into the correct tub according to the sort plan.
The post office will pay anything to shed workers but that is true of all industry these days. Your only hope is to be the guy who fixes the machines.
3PSI gauge0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
