cast iron baseboard minimum supply temperture
johntrhodes81
Member Posts: 44
On a modcon system with cast iron basebord. What is the suggested minimum temp for supply? Right now i am using 115* for minimum temp for odr. Should i go lower? What temp will the radiation stop?
Thanks for the help.
John
John
Right but i can drop the supply temp and the outdoor temp it is associated with. What minimum do most suggest for ci bb?
Thanks.
John0 -
It really depends on the heat loss and the length of your baseboards. If you have a well insulated house and lots of baseboard, you can go pretty low. I'm heating with fin tube baseboards and use supply temps in the 90s when it's in the 40s or 50s outside. Heat output of my baseboards drops noticeably at supply temps below 95F.Hydronics inspired homeowner with self-designed high efficiency low temperature baseboard system and professionally installed mod-con boiler with indirect DHW. My system design thread: http://forum.heatinghelp.com/discussion/154385
System Photo: https://us.v-cdn.net/5021738/uploads/FileUpload/79/451e1f19a1e5b345e0951fbe1ff6ca.jpg0 -
I think it should be noted, that, at any temperature above ambient, there will be an output. That's not to say it will be sufficient to maintain the temperature in the home. I think the best way to establish the curve is the way that SWEI always described. Crank the thermostat up as high as it will go, and begin changing your parameters until the temperature in the home is maintained. It may take weeks of tweaking.1
"It really depends on the heat loss and the length of your baseboards. If you have a well insulated house and lots of baseboard, you can go pretty low. I'm heating with fin tube baseboards and use supply temps in the 90s when it's in the 40s or 50s outside."
For sure. I have lots of fin-tube baseboard upstairs in my house and a mod-con boiler with outdoor reset. 14 feet of Slant/Fin in each of two rooms. (They used to have three feet in each room, which was too small.) Slant/Fin have tables that show how much heat will be delivered from their products based on the difference in temperature between the supply temp and the room temp.
For example, here is the listing for my baseboard (yours will surely be different):
http://www.slantfin.com/wp-content/uploads/2015/11/BaseLine-2000-Ratings-514.pdf
When it is 50F or higher outdoors, I put 120F water into the baseboard; when it is 0F outdoors, I put 150F water into the baseboard. The 120F was picked because that zone does not have a lot of heat loss and my boiler will not modulate low enough to prevent rapid cycling. So I run it hot to get it up to temperature and satisfy the thermostat fairly quickly when it is warm outside. As it gets cold enough outside, the boiler can cycle much more slowly.
As Paul48 said, any temperature above ambient will deliver some heat. In my radiant slab heated zone I put 80F water into it until outdoor temperature gets below 50F, and increase it to 130F if it gets to 0F outside; since design temperature around here is 14F, that hardly ever happens.0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 970 Plumbing
- 6.3K Radiant Heating
- 385 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
