Need a flush cart?
hot_rod
hot_rod Member Posts: 27,841
Not really a cart, more of a hand carry. Holds fluid in the tank "bowl" 1/2 HP stainless Grundfos sump pump. Barely used.
This has a flow reversal valve also, flush from two directions. Metric hose connections would need some adapting, or connect onto the hose barb fittings included.
$375.00 plus shipping. It is fairly heavy, about 35lbs.
$25.00 goes to the HH Wall.
