Sight glass
daveamir
Member Posts: 69
Hi guys good morning, just wondering is it normal to have this condensate build on my sight glass in the picture I've attached. I've never noticed before I just changed all my vents to gorton could that be a reason thanks
Very slightly, how would I skim thank you0
You could be very lucky and have had a skim port installed by the installer.......more often not.
Pictures of the boiler & piping would tell.0 -
On the right side of the boiler is a round plate with six bolts. If that plug in the center can be removed there is a good spot for a skim port. Add a nipple and a cap.
The other item I noticed is the temp/pressure relief valve has too short of a pipe pointing down and the open end of the pipe isn't suposed to be threaded.0
- 119 Geothermal
- 394 Solar
- 50 Industry Classes
