repeated corrosion on hot water outlet
clammy
clammy Member Posts: 3,242
Replace a standard 50 gal failed hot water heater about 2 years ago and it had a few years on it about 12 .Just happened to have a buddy who gave me a new warranty tank (ho wanted a bigger tank )i installed it all good n nearly 1 year pass and the tank developed a leak on the back side about 2/3 up . i pull it install a new warranty tank and now just about 1 year to the day the HO tells me they notice corrosion on the outlet di electric nipple ,i go and take a look and sure enough theres some corrosion .there is no visable leak at my connection or where the nipple is threaded into the tank .The tank is bonded just wondering i am going to re chk for stray voltage ,the home is on city water and it s not like theres 6 people there only 2 .Was planning on pulling the nipple and chking anode rod even though the first warranty tank s anode was near perfect and the tank had been flushed regularly .peace and good luck clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,006
    Hi Clammy, It would be nice to see a photo of the corrosion, and location of the bonding wires. But one thought is that if you used a flex connector with dielectric built into the end, it's pretty common that the rubber washer in the end of the flex shrinks with heat and needs to be re-tightened after about six months. If it's bonded and grounded back to the main panel, you shouldn't be getting stray current problems. Any thoughts about the water quality?
    Yours, Larry
  • clammy
    Thanks larry no flex brass npt x copper sweet union bonding is about 6 to 8 inches above havent had time to change it out .i think it may have weeped past the plastic insert i ll have to see
    NJ Master HVAC Lic.
    Mahwah, NJ
    hot_rod Member Posts: 26,580
    get rid of the dielectric unions, the create more problems then they solve. Dielectric flex connectors, copper or braided stainless.
    Is there a water softener? Softening increases the TDS and increases corrosion if you have any leak or seep at the joint.
  • MilanD
    MilanD Member Posts: 1,162
    Check also upstream cold line. There may be break in the ground if softener or plastic filter housing was installed but not jumped/bonded over.
    EBEBRATT-Ed Member Posts: 19,577
    Not a plumber so I don't do water heaters except my own but I have walked by many and seen crusted up dielectrics.
    A plumber buddy told me to put dielectrics on mine the last time I changed it. "your water heater will last forever"
    I put them on, within a year the dielectric unions leaked. Maybe others love them but they don't work for me
    MilanDCTOilHeatCanucker
