Return leg radiator
curiousburke_2
Member Posts: 70
Hello All,
I'm getting in some last minute tweaks to my one pipe steam system before the cold. One is that I want to hook up a radiator in my garage on the return leg. This was the original configuration of my 1926 home, and a giant radiator (with a big hole) still hangs on the wall. In any case, I have a spare large radiator, but how the heck do I remove a second opening to make it a two pipe radiator? The plug hasn't budged with banging, burning and general swearing at it. Any help would be appreciated
Small hole saw.... then saw out the sides.0
Like @kcopp said. Also the plug will be cast iron most likely. It will take some careful cutting with a hole saw and metal saw and probably a little cold chisel work. Patience0
Okay, make it into a pipe, then cut it out. Thanks! This is going to take some time. Hopefully it's hollow0
- 117.6K All Categories
- 82.8K THE MAIN WALL
- 2.7K A-C, Heat Pumps & Refrigeration
- 43 Biomass
- 403 Carbon Monoxide Awareness
- 8 Chimneys & Flues
- 1.6K Domestic Hot Water
- 4.3K Gas Heating
- 107 Geothermal
- 148 Indoor-Air Quality
- 2.7K Oil Heating
- 45 Pipe Deterioration
- 681 Plumbing
- 4.8K Radiant Heating
- 353 Solar
- 13.3K Strictly Steam
- 2.9K Thermostats and Controls
- 48 Water Quality
- 31 Industry Classes
- 65 Job Opportunities
- 12 Recall Announcements
