hydro-pac vrhc 57-36 air handler AC R-410a upgrade
mrgavitt
Member Posts: 1
I have a hydro-pac 57-36 made by VRV Products of Benton Harbor, MI installed in 2004.Compressor has failed and contractor wants to upgrade to r-410a, but says that the entire attic unit must be replaced. I'm wondering why they cant install a new r-410a compatible coil in the attic unit and new lines and new compressor. I tried to contact manufacturer, but can find nothing on them. I was given no paperwork on these units by the installer back in 2004 when the house was built, so I don't even have owners manual, never mind parts list or install manual. Anyone have any suggestions?
Van
Van
Do the complete upgrade. A replacement evaporator coil is probably not available due to minimum SEER ratings required. (A new evap. won't fit in the existing A/H).
Sometimes you can change the TXV, but on a 14 year old system, it will be beneficial to upgrade everything. If you opt for high efficiency (16 SEER or higher), you'll save on electric consumption.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 5.7K Gas Heating
- 110 Geothermal
- 161 Indoor-Air Quality
- 70 Pipe Deterioration
- 999 Plumbing
- 6.3K Radiant Heating
- 391 Solar
- 15.4K Strictly Steam
- 55 Water Quality
- 45 Industry Classes
- 48 Job Opportunities
