DIY Hydronic install
NormC
I am installing a Chiltrix CX30 with two fan coil units. I want to make sure that my piping layout is correct and that future additions of solar heat pipes w/ buffer tank is taken into consideration.
I currently have the chiller, two fan coils and 100' of 1" Pex-Al-Pex. I will be purchasing fittings from pexuniverse.com. Would anyone like to look at my layout design?
Planning on a reverse return loop with wild coils.
I have a licenced plumber that has agreed to check my work and do the Purge-and-Fill.
I'm happy you posted this. I'm looking at getting that Chiltrix. It sounds perfect for my situation. Please update us on how things go and it's performance. I'd like to know more!
Thanks for the reply. The Chilltrix is a air to water heat pump not a boiler. Max temp is around 130f. Thanks tho.Paul Pollets said:I'd consider piping with copper due to the higher temperature requirements of the coils. Especially if you're sending 180 degree water to the coils.
Here is my fittings layout. Am I missing anything?
Sorry for the potato quality of image.
Starting with the supply side I have:
1" Coupling
MNPT x FNPT Union Elbow 90
MNPT x Pex-Al-Pex Compression
1" Pex-Al-Pex => attic
Distribution and collection Tee are the same.
1" FNPT x Pex-Al-Pex Compression
MNPT x C
1" x 3/4" x 3/4" C x C x C
3/4" Pex x 3/4" C
3/4" No-O2 Pex
At the fan units:
3/4" Pex x FNPT drop ear elbow (drawing is wrong)
nipple
Bellows
Ball valve
(Return side of fan is the same as above excluding ball valve.)
On the return side starting after the collection Tee:
1" Pex-Al-Pex Compression x MNPT
Purge & Fill valve
nipple
Wye-Strainer
nipple
MNPT X FNPT Union Elbow 90
Ball valve
Image attached.
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
