Steam Boiler Leaks O2 pitting
RayWohlfarth
RayWohlfarth Member Posts: 1,702
I am seeing a disturbing trend of O2 pitting inside low pressure steam boilers. One vertical fire tube boiler was only 2 1/2 years old and the customer has a water treatment program using a sulfite treatment. Another was a 9 month old horizontal water tube without treatment but used a softener. A two year old cast iron sectional without treatment had a leak just under the water line. I am not sure what the cause is. Some believe it is because of fracking and there is something in the water while others think it is chlorides in the water. I have spoken to water treatment experts and they are saying we need increase the sulfites. Are you seeing this trend?
Ray Wohlfarth
Boiler Lessons
    hot_rod Member Posts: 24,646
    We are seeing water quality issues in ALL types of boilers. Check TDS, hardness and ph at every jobsite, with fairly inexpensive meters.
    More analysis would involve a sample to a specialist.
    Steam boilers have a bit different water spec, find their recommendations in the installation manual.
    Most all of the chemical manufacturers will test water and make a suggestion for treatment, here is an example from Rhomar.
    I agree the stuff we are putting into and onto the ground, as well as new chemicals that water providers use are creating more and different issues with piping and boilers.
    I think we all need to start paying more attention to what goes in the systems,as well as a good cleaning procedure before filling.
  • RayWohlfarth
    Thanks Hot Rod Good point
    Ray Wohlfarth
    Boiler Lessons
  • ColinFarquhar
    ColinFarquhar Member Posts: 16
    What ppm of excess SO3 are they keeping in their boilers? Are the boilers on line all the time, or are they shut down on weekends/etc? I've seen some older boilers that are infrequently used with corrosion issues due to not enough treatment (phosphate and pH too low, so the steel doesn't have a chance to get it's protective magnetite coating).
