Condensing tank type water heater nat gas 95%??
GW
Member Posts: 5,156
in Gas Heating
My ahri searching skills are on the fritz, does anyone make a 95% tank type water heater nat gas? AHRI doesn't seem to think so.
Lochinvar has the 96% Shield in commercial models. Not sure about residential.Steve Minnich0
http://www.hotwater.com/water-heaters/residential/gas/proline/xe/vertex/vertex™-100-power-direct-vent-50-gallon-gas-water-heater/
State makes one too, not sure of the model or if it's AHRI certified.
Found HTP's Phoenix lineup too: http://www.htproducts.com/phoenixwaterheater.html
and American's Polaris line: http://www.americanwaterheater.com/residential/gas/pg10-50-199-3nv/
the only one whose literature indicates AHRI is the AO Smith though I didn't check the AHRI database but some might be Energy Star certified if rebates are an issue.0 -
Thanks all, somehow the htp site says 100 rebate. Not sure why0
Gary , Here's what to look for specifically with the HTP units , as well as the others . Most of the condensing storage heaters will appear as commercial units , everything above 75K input will appear as commercial . i have yet to see a program however that did not recognize it's use in a residential application . Someone mentioned the Crossover , this will be listed in both the commercial and residential sections , considering the model number , RGH 20-75 would be found in the residential listings and RGH 76 would be found in commercial listings , all Phoenix will be found in commercial listings and I believe the Phoenix Light Duty can be found in both . Mind you and I will stand corrected if wrong , only the HTP units are modulating also .
http://www.htproducts.com/literature/RGH75100-brochure.pdfYou didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
Are you looking for 95% recovery/thermal efficieincy or .95 EF -There is a big difference
(No .95 EF tanks I'm aware of)0 -
I installe a HTP PH76-50 in my hoouse last August. My gas bill in Septemebr and October was 47% less. I also do not run out of hot water even when showering with the rain forest head that has been drilled out, washing machine running and dishwasher running.
htproducts.com/literature/Phoenix-LD-Brochure.pdf
The HTP is 97% efficiency0
- 87.4K THE MAIN WALL
- 122 Chimneys & Flues
- 15.8K Strictly Steam
