Old Lenox BX2-28-350-2N Equivalent
Bob_51
Member Posts: 6
Does anyone have a cross for this old lenox unit, tried their site, doesn't mention it even in their obsolete section, or a way to crack the nomenclature.
Thanks,
Thanks,
http://tech.lennoxintl.com/C03e7o14l/VIu12Ch2uV/us_ehb_gcs3-953-2753_7205.pdf
350,000 btu input 262,500 output heating. about 11 tons of cooling
The # you have is a serial # not a model #
model is a GCS3 you can find the entire spec sheet above
I believe what I found is the unit your looking for1 -
Thanks!0
