Main steam vent
dc07736
Member Posts: 15
Hi,
100 year old system.
1 pipe steam.
Original system did not have a main steam vent.
Do I need one now?
What would the advantage be?
DC Kingston NY
1 pipe steam.
Do I need one now?
DC Kingston NY
Old coal fired systems were always hot so they only suffered the lack of main vents sporadically. Modern on/off oil and gas fired steam boilers have to expel air a dozen or more times a day in cold weather.
Money is being sent up the chimney whenever a boiler is firing. If you don't mind paying money to squeeze the air out of the radiator vents then leave it like it is. If you want to save money and allow the system to work better, install a main vent on each steam main and make it a great big one!
3PSI gauge1 -
