Indirect water heaters
bob eck
Member Posts: 930
What brand indirect water heater do you use? Why do you use this brand? Was there a brand that you were using that you do not use anymore and why?
We just installed a Bradford White Powerstor SS - RTV-40 last year. It was between that and the Lochinvar SIT040 but the grade of SS (titanium ferritic 444 stainless steel) is what tipped the scale to the Powerstor for me. This is my first indirect, it replaced a Bradford White fired tank that lasted 15+ years and was still going strong. That fired tank replaced a long line of electric tanks that each leaked almost from install and went through elements like crazy. The plan is for the Powerstor SS to be the last tank I have to install before I'm ready for the old folks home.
We love it. Boiler runs maybe twice a day to heat it and we couldn't run it out of hot water if we tried.0 -
I spec HTP SSU indirects. Install and forget about it in my lifetime! They finally sent me the pressure drops for different flow rates after 3 years of asking. I can now get more than the minimum flow rate of the boiler into the coil.0
I've had great luck with Heat-Flo, in fact I have one in my own house. We see a lot of Vaughan "Top Performers" with leaking top gaskets, and the most popular is Amtrol "boiler mate" which I simply don't care for. Finned tube copper coils are poor performers long term, same goes for the Vaughns finned copper coils. They get high numbers when new, but quickly fill with minerals and end up being bottom performers.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
- 87K THE MAIN WALL
- 57 Biomass
- 111 Chimneys & Flues
- 5.7K Gas Heating
- 106 Geothermal
- 70 Pipe Deterioration
- 978 Plumbing
- 6.3K Radiant Heating
- 387 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
