Why do you want your main steam vent to be at least 6" higher than the horizontal return?
kiemside
kiemside Member Posts: 10
I have a one-pipe steam system. I have two main vents, one for each return (one from the front and one from the back sides of the house). The vents are current situated at the horizontal return. I just bought two Barnes & Jones Big Mouth Vents to change. I keep seeing the recommendation of putting your main vent at least 6" higher than the horizontal return but I never see any explanation. Why do you want to have your vent at least 6" higher than the horizontal return?
    Steamhead Member Posts: 18,561
    So if there's any water hammer in the pipe, the vent will be up high enough that it shouldn't be affected that much.
    Consulting
  • kiemside
    thanks
    EBEBRATT-Ed Member Posts: 20,280
    You want to reduce the possibility of condensate (water) getting into the vents. Keep it high and dry
