Carbon Monoxide Poisoning
A story out of Islamabad talks about the dangers of CO poisoning from Gas Geysers in bathrooms. Over 100 poisonings were reported last year. Here are some short excerpts:
1. Altering the temperature frequently while the geyser is on can lead to incomplete combustion,
2. LPG cylinders attached with instant geysers contain mixtures of hydrocarbon gases that are extremely inflammable.
3. Health experts say that the gas geyser should not be switched on after locking the bathroom from inside, ventilation should be kept open and gap should be maintained between two people taking bath to avoid increase in the carbon monoxide density.
4. Dr. Haroon said in case of gas leakage and or stay for longer period of time in a bathroom that is not well ventilated carbon dioxide gas is retained in the body and oxygen levels deteriorate to dangerous limits causing permanent brain damage and death.
Oh yes, a gas geyser is not a big fart, it is an instantaneous water heater.
I was just about to ask what a geyser is.captainco said:Sometimes stories about CO poisonings do have some humor, well sort of.
#2, isn't this the entire point of the cylinder?
#4, should that be Carbon Monoxide, or Dioxide?
1 -
Just ask Meryl Streep, she knows they get it right!!0
You can die from carbon dioxide poisoning too, but it is more difficult. 5000 ppm of CO2 can be fatal. It takes only 100ppm for CO. The real baddies are Phosphine, Arsene, and Hydrogen selenide: 0.05 ppm. Hydrogen cyanide is 10 ppm.0
- 120 Geothermal
- 394 Solar
