A thermal, balancing valve
hot_rod
hot_rod Member Posts: 27,841
To balance a multi loop recirculation system. It also includes an anti legionalla function. This allows the valve to go to a higher temperature. It can be accomplished with an electric actuator, or if it sees 160F supply it goes into high temperature mode.
