Convectors
Member Posts: 149
Hello All,
I'm trying to find BTU loads of hot water wall convector. I need to install two new ones and I cant seem to find anything on line on who make them and sizes. I need to do a kitchen with about 7,300 btu's heat loss and I need two convectors.
Any help to show me when to look would be great. Governale only seems to have replacement elements.
Can you post a photo of the one you are trying to match. Also can you provide measurements?Hydronics inspired homeowner with self-designed high efficiency low temperature baseboard system and professionally installed mod-con boiler with indirect DHW. My system design thread: http://forum.heatinghelp.com/discussion/154385
System Photo: https://us.v-cdn.net/5021738/uploads/FileUpload/79/451e1f19a1e5b345e0951fbe1ff6ca.jpg0 -
I have no photo. I need to remove a 64" and 24" convector an replace the 64 with something that maxes out at 44" the 24 could be made bigger up to 48". It's the old style 6" deep, 24" tall, with the removable grill. Single steel element.0
