noisy radiator
i know i have posted about this before, but i still don't have a definitive answer. i have a one-pipe steam system, gas fired. i replaced the boiler about three years ago. i pitched all the radiators toward the pipe. there is one radiator, the one furthest from the boiler, that is very noisy. it sounds like there is water sloshing in the radiator. after the plumbers installed the new boiler they put in Pure Pro Steam Boiler Cleaner which quieted down the system quite a bit, but there is still noise. the radiator gives good heat. i have vent-rite valves on all the radiators and the pipes in the cellar are pitched. i never had this trouble with the old boiler. any ideas?
  • KC_Jones
    KC_Jones Member Posts: 5,907
    Have you checked that the inlet valve is fully open? Have you verified the inlet valve isn't broken? On occasion they can break and even though you think it's open it actually isn't.
    What does the boiler piping look like (pictures)? How is the boiler performing? Is the water line fairly steady (no surging)?
    It's typically either wet steam, bad pitch, bad valve or a combination of those 3.
    If this is new with the new boiler my gut tells me something they did with the install, either directly or indirectly.
    2014 Weil Mclain EG-40
  • Fred
    Fred Member Posts: 8,542
    Did they by any chance replace the supply valve on that particular radiator? Some of the new, cheap valves are made to look like they are the same as the older ones but the throat of those valves is much smaller, causing the rad to hold more water in it.
  • Joseph Zizza
    Joseph Zizza Member Posts: 8
    i was told by the plumber to install vent-rite valves on all the radiators. are they the wrong valves?
  • Fred
    edited December 2016
    Vent-rites are good vents.
    http://www.hvacrsupplynow.com/VENT-RITE-1-STEAM-AIR-VALVES-ADJUSTABLE_p_1787.html
    I doubt that will resolve noise and the sound of water sloshing. Did they ever skim the boiler? It may need another slow skim from the skim port. What size is the supply pipe to that radiator?
  • ChrisJ
    ChrisJ Member Posts: 17,068
    We need pictures of the boiler, all of the piping around the boiler and a few of the radiators please.
  • Joseph Zizza
    they did skim the boiler. i have the empty jar at home of the stuff they used. i know the water turned a light green. the plumber told me to let it run thru for a couple of days and then flush it out and replace it with clean water. i know they took off the vacuum relief valve, mixed the stuff with water and poured it into the boiler, replaced the vacuum relief valve, filled the boiler and fired it up. this quiteded the system down quite a bit, which makes me think that this is what i need to do again.
  • Fred
    That's not a skim. That's just flushing the boiler out and doesn't remove the oils that float on top of the water. When you flush, the oils cling to the sides of the boiler and then re-float on the surface as you add new water. To skim, which I think is what you need to to use a port, above the level of the water in the boiler, you add water to the boiler until it starts to trickle out of that port (Called a skim port) and you let it trickle (stream no larger than the diameter of a pencil) for 20 or 30 gallons. It should take a couple hours to fill a five gallon bucket. Only that slow process will allow the oils to float off of the top of the water and out the skim port. I usually set the trickle and then put a garden hose on so that it can run into a floor drain and I let it run over night.
  • Joseph Zizza
    thank you. i think you are right. that's what i need to do. thank you.
