Steam radiator valves
marde239
Member Posts: 5
Hello. What is a better valve varivale adjustable or Gordon? I have steam. Aseboard and cast iron radiators. Cast iron radiator ms have some hissing and banging. Steam badeboard spits some water.
Does the system have main air vents on the steam mains and what kind are they? A lot of systems can benefit from faster main vents. What pressure is the system running at, it should be no more than 2PSI and hopefully lower.
Heatimer Varivalves are usually too fast for radiators and definitely not for cast iron base boards. Depending on your system you would be better off with venrite adjustable vents or maid o Mist 5L that comes with 5 different orifices.
3PSI gauge0
