Honeywell RTH6500WF installation
staver
Member Posts: 2
Looking to install this unit. Says you need to have the C wire (ie. blue) in order to install. I have the wire but it was just wrapped up and pushed back into the wall so it was not used on the old thermostat. At the heater the blue wire is also just wrapped up and not used. My question is can I actual just use the blue wire on the unit and then attach the blue wire into the C port on the heater? The C port on the heater actually has two white wires already attached but they do not seem to have anything to do with the thermostat wiring.
Thanks.
Thanks.
Probably. What kind of heater is this, and what kind of controls?0
As long as its the same blue wire and no one spliced the wires in other areas.....thats what you have to find out....i would just hook it up and see what happens...is this a furnace? The other 2 white wires on the C terminal ....could be for the air conditioning and humidifier....if its not the same wire you may have to call a pro or run new wireASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
Worked perfectly Paul! Thanks alot!0
- 125 Chimneys & Flues
