Adarad Dokum Oil fired boiler
Marz
Marz Member Posts: 90
Was hoping to find some OEM settings on this Adarad Dokum Oil boiler with Riello burner. Can't seem to get the CO under 200PPM. Tried different nozzles, head/air/pump adjustments. Gave up after 2.5 hours. First time seeing this Turkish boiler in my career. Any info is appreciated. Model number is DK4
  • Scott M_2
    Scott M_2 Member Posts: 26
    Marz,try George Lanthier at fire dragon enterprises he may be able to help or at least steer you on the direction.
  • Marz
    Thats exactly what i did Scott! Turns out it's the successor for Pensotti. Found the tables in the Riello OEM book. Going to start with those. And thank you!
    kcopp
    EBEBRATT-Ed Member Posts: 17,350
    make sure the boiler is up to temp, they make co when cold also too much air can chill the fire and can cause co as well as too little air. Shouldn't be that high though
