upside down steam trap
jclark
Member Posts: 14
is it common to see upside down steam trap installation? what problems would occur from installing a f&t trap upside down?
I knew it was a questionable question to ask didn't seem right to me but im no pro at steam and surprisingly in my 3 yrs of dealing with an industrial 2 pipe system and dealing with at least 5 companies that claim to understand steam. I decide to rebuild the traps myself and it took me one time to say this cant be right. im at a loss of words that so many could miss this. I will try and get some pics up. thanks for confirming what I thought as weve had water hammer problems and steam pouring out condensate tank for a long time with many doing things that never fixed problem, hopefully this does. will put update at later time0
Everything is possible. Found this Inverted Bucket trap installed backwards running 90 PSIG a couple months ago doing a plant tour. I was told it's been that way for years Imagine the steam wasted.
Peter Owens
SteamIQ1 -
will do n thanks don't know if you remember me but we talked a few months ago when I place an order for steam traps thru FW Webb and there was a problem with the treads on the thermostats. I do have a question for you I have an umarked trap and will need to get a rebuild kit for it next yr. Maybe I could send you a pic n some info and you might know which one it is.0
My pleasure, I do remember, 41T right?Peter Owens
SteamIQ0 -
42t if I remember right0
Yes,
That's a 42T and as you correctly assume, installed upside down. And most certainly blowing steam. I'll find a trap and take pics to show what I meanPeter Owens
SteamIQ0 -
Shows the float hanging down which pulls the plug off the seatPeter Owens
SteamIQ0 -
Well, they printed "bottom" upside down, how could they expect anyone to read it.
Also could this be plumbed backwards? It seems the trap was installed to line up with existing pipes.....you just rotate the trap around until the pipes line up with some holes and get er done!0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 5.7K Gas Heating
- 110 Geothermal
- 161 Indoor-Air Quality
- 70 Pipe Deterioration
- 999 Plumbing
- 6.3K Radiant Heating
- 391 Solar
- 15.4K Strictly Steam
- 55 Water Quality
- 45 Industry Classes
- 48 Job Opportunities
