(2) Vitodens 200 B2HB with vitotronic 300 control
Can anyone explain how/when the vitodens 200 fire on with the above set up? It was commissioned/start up by the sales rep techs, but hasn't needed to really fire on until a few days ago when it got colder. Yesterday, the loop temperature set point was 75 F and the actual loop temp was only 65 and didn't fire on (it later warmed up in the day and didn't need to go on (after a few hours)).
A few days ago it got even colder, but eventually did fire on when the loop temperature hit ~60 F.
I know Viessmann's have quite the controls, but I would like it to fire before the loop temp gets that far below the set point.
I know about the integral start threshold, but I adjusted that lower but yesterday when the loop temp hit 70, it didn't fire
Any light shed on the subject would be appreciated. I know once its on, it will modulate, but I really wish it would turn on sooner. The outdoor reset curve is pretty flat as it serves a water-source heat pump loop so the loop temperature stays pretty low during the heating season.
  • I did a little digging and on page 55 under the Cascade control of the Vitotronic 300 installation/service manual it says
    "Starting criterion:
    An output statement causes the boilers to be started
    (coding “3d:1” in the “Cascade” group)"
    My question now is what is an output statement. Looking under coding 3d does not give an clarification.
    I may just give tech support a call if no one has any answers.
