Slim radiator or angled feed/shutoff valve?
ADanemayer
Member Posts: 3
I recently removed a wall-mounted convection radiator from our single pipe steam system and need some help identifying the possible replacement options. The middle of the feed pipe is only ~1.75 inches off the wall and not movable (see picture). I looked at purchasing a new CI unit from OCS Industries but their slimmest offering needs at least 2.5 inches of clearance from the wall, and it is my understanding that the flat "European" style radiators are only for hot water systems.
As I see it, I have two options:
1) Replace the right-angle connector on the feed with a 120-degree connector (angled away from the wall) and then attach the shutoff valve to gain some space from the wall.
2) Find a slim steam radiator that can heat a ~90 sq. ft. room
Any advice would be very much appreciated!
Why did you remove the old convector? What size is that pipe? If it's 1" pipe, it will only support about 25 EDR. If it's 1-1/4" it will support 55 EDR. Do you know what size radiator you need? If You can turn that 90 degree elbow 45 degrees, relative to the wall, use a 45 degree elbow and a close/short nipple and get as much distance off the wall as you will need for just about any radiator.0
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 984 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
