Globe valves
Harvey Ramer
Harvey Ramer Member Posts: 2,281
Has anyone used Webstone globe valves for flow balancing? They are pennies on the dollar when compared to most other brands like Honeywell, for example.
    hot_rod Member Posts: 26,573
    Without test ports how would you know when you are balanced properly? Add a flowmeter somewhere? Or by temperature differential?
  • Harvey Ramer
    Were talking 2". Both Supply and return temp gauges and also pressure ports on the pumps.
  • SWEI
    SWEI Member Posts: 7,348
    Yes -- been using the 1/2" and 3/4" ones on drainback solar systems for a little over a year now. No problems to date.
