Weil-McLain EGH85 startup problem
MikeMens
Member Posts: 30
I have installed my pressuretrol, auto feeder, probe LWCO & float secondary LWCO and finished wiring everything up
skimmed it and went to start up and nothing - i should say it sounds like the auto damper opens then nothing. there is power top the transformer, the probe LWCO & feeder appear to be working OK. I' ve checked my wiring against the instructions and can't see anything wrong. gas regulator is wired in etc and gas valves are on. water level is correct.. any suggestions on troubleshooting?
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
