Aquastat - Oil -Gas Boiler Interchangable?
wgardner26
Member Posts: 9
in Gas Heating
Hello - I have a Crown CXE-5 (1997 vintage) gas boiler (150k BTU/HR, not high effiecency). I recently noticed the Honeywell L7224U1002 Aquastat a tech installed over a year ago is specified for use it oil boilers. Should I be concerned? My mechanical aquastat had failed.
Also, when scrolling through the digital settings on the Aquastat I noted the low temp cutoff is turned off. Is this correct? The high point is 199 and the differential is 10. I have 4 zones serving 3 baseboard loops and an indirect DHW tank. One circulator. I live in the northeast. I had the unit cleaned/inspected last fall with no issues. I have read some threads,with no firm conclusions, regarding cold start vs maintaining the boiler warm. I should note that the boiler temp never seems to exceed 140 and can linger in the 110 -120 range for very long periods in the winter (likely related to my system's inability to maintain the house temp during the winter).
Thank you.
Thank you.
I'd suggest you get a qualified pro in to check the system out. You most likely have a problem. The fact that a cast iron boiler never seems to exceed 140, and lingers in the 110-120 range, is cause for concern. If you take those facts and add them to the fact the boiler doesn't heat the house properly, there is definitely a problem.0
Paul - Thank you for your response. The service tech verified with Honeywell that this Aquastat can be used on my gas boiler. Apparently, this oil boiler aquastat has a 120v tap that is needed in my case to run the induction blower. He also reviewed the system and did not note any obvious problems. It was a warm day, so he did not witness the system being overwhelmed by cold weather. I will post a separate entry with details regarding my system.0
- 125 Chimneys & Flues
- 19 Recall Announcements
https://www.youtube.com/watch?v=L_-35UBA-Mw
