boiler tune up question
edot44
Member Posts: 8
in Oil Heating
Hi all-I have a fairly new (2013) oil burner its a Weil-McLain that operates a steam system Last year it was serviced at the end of the season in early march. Ideally I want to service in Nov, but just the way timing worked out (moved into new house) my question is..should i go ahead and have it serviced again in November or wait the full year and stick to march? appreciate your thoughts.
Was it used all summer?
it was not, was shut off. i guess my main concern is getting on a schedule where we tune up in the beginning of the season as opposed to the end.0
For what it's worth I always recommend getting the heating system tuned up in the fall and the A/C in the spring. Get it done before you need to use it0
I agree with SuperTech for those who have combination heating and Cooling duct systems... mainly for the air filter part of the maintenance.
In your case however, there are some boiler related maintenance items (especially on oil heat) that are better handled sooner than later. Water related repair like a leaking air vent on a water system or a leaking packing nut or gasket can become more of a mess to address after it has leaked all summer. Also scale and carbon buildup in the flue passages will crust over and harden the longer it sits. March or April is good for you situation.Edward Young Retired
