Laars Endurance sometime gets domestic hot water sometimes not
Heater has no code or LO but reads 7 7 all the time. Anyone seen this before?
  • danitheplumber
    danitheplumber Member Posts: 98
    That reading of 7 dash 7 (7 7) srays on the dis play 24/7 no code or LO comes up to my knowledge
  • lchmb
    lchmb Member Posts: 2,997
    that's not a code I'm aware of. when your having hot water issue's is the boiler coming on or not trying to run at all? If it's not trying to run it could be a flow switch..
  • danitheplumber
    I don't see a flow switch at all but it's been running for over 10 years like that... I don't think the ignitor is turning on but then there should be LO code... when we hit reset it goes on
  • Aaron_in_Maine
    Aaron_in_Maine Member Posts: 315
    If your having an issue with hot water and not the heat. Then it is usually a flow switch issue if it's the old style it is in the cold water line above the flat plate exchanger. They make a retro kit to change it to a different style switch.
  • danitheplumber
    Turned out to just be the boiler control display
  • Boiler_Controls
    Boiler_Controls Member Posts: 3
    Hi Dan,
    I apologize for the delay. Laars will monitor this site closer in the future. While it looks like you've resolved this issue pls fee free to contact Bill Marchant, in our Applications Team, with any questions in the future. He can be reached at (603) 335-6300 ext.582.
    Rich Simons
    General Manager, Laars Heating
