flow control valves
Wayco Wayne_2
Member Posts: 2,479
I usually use B&G Hydrotrol valves when I need a Flow control valve. I love the product. It's not as big and clunky as the cast iron ones and can be installed in any position. However my current job needs a 1.5 inch valve and the Hydrotrol only goes to 1.25" Are there any other options?
How many GPM are you flowing? The 1-1/4 has low Cv
http://documentlibrary.xylemappliedwater.com/wp-content/blogs.dir/22/files/2012/07/A-411A.pdfBob "hot rod" Rohr
Living the hydronic dream0
- 87.4K THE MAIN WALL
- 121 Chimneys & Flues
- 15.8K Strictly Steam
