In search of a Direct vent steamer
Howdy wallies,
A client called today that the building next to him built up 4 stories above his residence and he is now required to raise his chimney. His architect recommend he go with a "high efficiency boiler". I explained he has steam and not hydronic heat, however a direct vent may be an option.
The residence is roughly 3000sq ft so we arent talking about a very big boiler here. DHW generation is a requirement here, most likely in the form of a coil rather then an indirect water heater.
Fuel is NG.
I am only familiar with one manufacturer that has a steam direct vent if i recall its burnham. That boiler doesnt have a coil.
Ideas welcome.
:NYplumber:
  • John Mills_5
    John Mills_5 Member Posts: 952
    Independence PV, though looks like no coil. How about a PVC vented conventional water heater?
    http://www.usboiler.net/product/independence-gas-fired-steam-boiler.html
    Of course could investigate an atmospheric vent boiler and a power vent kit like Tjernlund or Field Controls sells.
  • Henry
    Henry Member Posts: 998
    edited September 2016
    You need to measure the radiation for the sizing. Smith has the HE versions of the 28 now for 2% better efficiency. Get a condensing hot water tank like the HTP. It has 95% efficiency and modulates. Why heat such a large mass at 82% combustion efficiency??? You loose 8 to 10% in the boilker room.
  • Danny Scully
    Danny Scully Member Posts: 1,462
    In reality, you can direct vent any boiler. One option would be a slant/fin galaxy which has a coil option. Contact Field Controls and they can spec it out for you.
  • NYplumber
    NYplumber Member Posts: 503
    Henry, im aware of proper sizing technique.
    The added cost of an on demand will never pay for itself.
    Danny scully, i was hoping to find a system that comes from the factory rather then put together a system.
    :NYplumber:
