Good Things Come In Small Packages
New England SteamWorks
Member Posts: 1,529
Working on a one-pipe system with two mains and a counter-flow branch. Going through the darkness to find the end of the counterflow main in search of a vent I found instead a coin vent/bleeder. That was a first. I can see why perhaps they thought about using it (even though it could never work): No headroom. Just a few inches before the lath, which probably had plaster on it when this "vent" was installed.
newenglandsteamworks.com
Not a particularly long branch, so the 1/4" taping would suffice and there'd be no need to drag out the 700. Still, not much headroom! The lath could be cut away, but who enjoys that mess?New England SteamWorks
newenglandsteamworks.com0 -
And then I thought of Peter and his new Vari-Vent. The little vent that could. Big vent, small package. Thank-you Peter! (though I would consider putting a tiny hex key / wrench in the box for the adjustment if I owned Barnes & Jones
. New England SteamWorks
newenglandsteamworks.com2 -
That's probably a hygroscopic vent, which some attempt to use on steam- we take them off and put on real vents.All Steamed Up, Inc.
Consulting0
- 167 Indoor-Air Quality
