WiFi thermostat with slab sensing capabilities
Started a radiant job, and contractor has asked me about WiFi thermostats, I do have slab a sensor installed. Anyone install a WiFi thermostat with slab sensor capabilities? Please let me know brand and model thanks.
    hot_rod Member Posts: 27,830
    I think some models of the Ecobee will accept a sensor like the tekmar. Best to have a sensor well to slide the sensor in and out as needed.
  • Gabriel@HBX
    Gabriel@HBX Member Posts: 9
    HBX now has the Wi-Fi Zoning System with a 2 wire thermostat, zoning module and Wi-Fi module. The thermostat can use a room sensor, floor sensor or combination. The thermostat communicates with the zoning module and can be controlled from an app on your smartphone or tablet. Because the system not the Stat is Wi-Fi you can have as many thermostats for one system on your app as you'd like.
    Comfort
    Control
    Innovation
