WM Aquaplus and cold start?
Hi,
I installed an aqua plus indirect hot water heater last week to replace an amtrol and the wiring diagram for the aquaplus heater said to install a r845 relay and connect 5 and 6 to the aquastat, which I did. Now the boiler only goes on when the hwh calls. Is this cold start? The boiler is a 25 year old WM 868 steam boiler.
Before this , the boiler was wired straight from the aquastat to the relay and used to come on when the aquastat in the boiler said to and maintained a temperature of 170 degrees.
Which wiring do you guys recommend? Maintain boiler water temperature all the time or only come on when the r845 and indirect calls?
Much appreciated
  • Peteys
    Peteys Posts: 79
    Anybody?
    Am thinking as it's in a 5 family house, there would be hot water usage every day and it wouldn't truly be cold start. Would like to get a few more years out of the boiler and not sure if this would be rocking the boat.
  • Timothy77
    Timothy77 Posts: 15
    I agree, but also as peteys says it's a five family home. Initial first call for the demestic hot water May be a little slow responding. I think I would try it and see how it responds if it doesn't work then do the mixing valve. Just an opinion.
