Can anyone identify this radiator?
SethK
SethK Member Posts: 43
I thought it was a Verona but the design is different and so are the specs. It seems to come in a 21" and a 27" tall model (maybe others) and is 3" wide per section, and 10" or 11" deep.
Other questions: do you think I could convert it to steam, assuming I could get this over-6-foot long beast into my house? Any suggestions on moving it? I'm guessing this thing must weigh 500 lbs at 6'x21"...
  • JUGHNE
    JUGHNE Member Posts: 11,357
    1 pipe or 2 pipe steam?
  • SethK
    I have 1 pipe steam.
  • You could run a forced hot water loop of the bottom of the steam boiler, and have a separate zone for the radiator...
  • Danny Scully
    Danny Scully Member Posts: 1,455
    It most certainly can be used for steam. Additionally, you could probably remove every other radiator in your house :wink:
    Canucker
  • JUGHNE
    Is this to replace an existing unit or a new addition?
  • SethK
    edited June 2016
    This would be to replace a large radiator in a bay window with window sills 24" high. I currently have a 22 segment 44" x 26" (27"?) tall corto (EDR 66?) in a large living room that requires 59 EDR (depending on source and if we raise the dropped ceiling from 9' back to 10').
    I wanted to do the math on this radiator to see if it would be closer to the EDR we need without blocking the bay window (maybe even put a bench over it, the cats would love that), but I can't look up the EDR without knowing it's name.
    CharleysHorse
    Steamhead Member Posts: 17,636
    I've seen those but still don't know the make and model. But the EDR chart for the Verona should be close enough to use.
    Consulting
    CharleysHorse
  • CharleysHorse
    CharleysHorse Member Posts: 11
    edited June 2016
    If you need spot on specs,i would contact consumersplumbing.com Lake St.,Chicago..Not that im experienced in this field,only because i have been on the look for radiators the last several months,and my guess of the brand of yours is by American Radiator Co....and i had looked at a smaller version,with the same scrolling details.
    Not a Rococo. The Rococo was a column radiator, this is a flue-type.
    Consulting
