tigerloop confusion
chuck172
Member Posts: 90
in Oil Heating
I'm installing a roth tank outdoors. The bottom of the tank will be 6' above the oil burner. Will there be any problem with this overhead piping? Any special precautions?
Are you going single pipe?
Just the usual-all flare fittings, OSV, power purge for air. Judging from the post title you're putting in a Tiger Loop?
Isn't this a continuation of your last post?There was an error rendering this rich post.
This is related to my last post, but addresses a different problem.
In the following link from the tigerloop installation directions :http://www.spxflow.com/en/assets/pdf/TigerloopUSA.pdf figure nine shows the required trap in the installation.
Tigerloop also states: "If the tank is located above the ULTRA
TM
, an oil safety valve (ie.
Westwood Products No. S225) is strongly recommended. If the inlet pressure
will exceed 8 PSI, an oil safety valve
must be installed"
With the tank bottom being 6' above burner, how much pressure will the inlet pressure be?
.0 -
A gravity tank is only going to create ounces of pressure not pounds. OSV are for pressures above 3PSI. I see no reason for it. Don't really see a reason for a Tiger Loop on a gravity system. If there is air there is a leak. Leaks need to be fixed or you end up with a sooted up furnace and call backs.0
Okay the OSV is still needed in case there is a break between the OSV and the pump, but it won't do much good if the leak is between the OSV and the tank which is more likely I would think.0
