Model numbers?
Do you guys put model numbers on your estimates? Sometimes i think the customers use it against me....i do not put the size of the equipment.....i state on my estimates that i will perform a heat loss/heat gain before starting job. What do you guys do?
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
[email protected]
ASMHVACNYC.COM
347-692-4777
[email protected]
ASMHVACNYC.COM
Leave a Comment
- 80.9K THE MAIN WALL
- 2.5K A-C, Heat Pumps & Refrigeration
- 36 Biomass
- 394 Carbon Monoxide Awareness
- 2.6K Controls
- 1.4K Domestic Hot Water
- 3.7K Gas Heating
- 100 Geothermal
- 130 Indoor-Air Quality
- 2.3K Oil Heating
- 30 Pipe Deterioration
- 563 Plumbing
- 4.2K Radiant Heating
- 333 Solar
- 12.1K Strictly Steam
- 36 Water Quality
- 7 Industry Classes
- 7 Recall Announcements
Considerate People, Considerate Service, Consider It Done!
732-751-1560
email: [email protected]
www.langansplumbing.com
347-692-4777
[email protected]
ASMHVACNYC.COM
Absolute Mechanical Co. Inc.
www.AbsoluteMechanicalCoInc.com
347-692-4777
[email protected]
ASMHVACNYC.COM
732-751-1560
PHC News Columnist
Minnich Hydronic Consulting & Design, LLC
https://heatinghelp.com/find-a-contractor/detail/minnich-hydronic-consulting-and-design
732-751-1560
Rich McGrath 732-581-3833
"Replace heating system .... $XXXX.XX"
347-692-4777
[email protected]
ASMHVACNYC.COM
There have been many times when they've come back and asked if there is a less expensive way than my initial proposal detailed and then I'm more than willing to change the scope. That's just part of the process.
But if a customer chooses a contractor based on the homework that I did and this contractor is foolish enough to install a system based on calculations from someone they don't even know, then they deserve each other. Knowing the plan and having the ability to execute the plan are two different stories.
PHC News Columnist
