199,000 BTU tankless
Davis
Davis Member Posts: 1
I need four tank-less nat gas water heaters. The Palomas I have used in the past worked out great for many years. I replaced them with the ones that have a "parent". They last for two months before the heat exchanger starts to leak destroying everything under it. Has anyone had a good experience with 199,000 BTU heaters that can be linked together?
  • kcopp
    kcopp Member Posts: 4,695
    What units have you had that are falling apart so fast.? Most have a 15 year warranty.
    Noritz makes a great unit. I have been using State for a couple years now. Rinnai is good too.
    All are in the 199K range.
  • nicholas bonham-carter
    What is a parent for these?--NBC
  • SWEI
    SWEI Member Posts: 7,342
    Generally good experiences here with State/Takagi.
