Cut and run
happydave
Member Posts: 79
Back to the small stuff, simple, neat, clean and not leaking CO
Right side, sad that the factory wiring harness was on the wrong terminal for the circulator. We also used the new Taco feed and back flow prevented, face to face the same dimension as a Watts sb1156f0
A feed and back flow the same size as a watts feeder?0
- 120 Geothermal
- 394 Solar
