Life Expectancy of a HTP Phoenix Light Duty
Le John
Member Posts: 250
would anyone know what the average life span of this boiler is?
Phoenix Light Duty is not a boiler LeJohn . The unit is only available for a short time as of now and longevity should be fine if used and maintained properly dependent on how it is being used . How exactly are you using it ?
Warmboard uses the base unit as a heating source for their WarmSource system , maybe a look there at the warranty and specs will give you an idea . The unit is of very good quality and taken care of should last quite a long time .
Warning
Don't try to buck the system and purchase online in an attempt to save money , it does not work . Purchase from a reputable wholesaler and have a qualified installer do the install . By qualified I mean someone who will read the Manual and perform the install and combustion analysis as per manufacturers specs . This is not a specialty item either , do not equate a master plumbers license with qualification . It's a new world now and some guys who sucked in the ol;d world are still attempting to suck worse in the new one . Manufacturers and customers are the only ones to suffer from this phenomenaYou didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38331 -
Feel free to contact me by pm or phone if you'd like . Do not have time to dispell or rebutt others misinformed comments on the forum .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330
- 120 Geothermal
- 394 Solar
