slantfin boiler
s150dp field control damper does not operate -if you jumper burner fires-but if you disconnect thermostat burner does not shut off any thoughts -with damper hooked up voltage drops to 14 v disconnect harness 24 volts - yellow wire comes off z on aqua stat relay to harness
    Steamhead Member Posts: 18,710
    Motor assembly on the damper may be bad. A replacement motor assembly is available. Not sure if you're a pro or not- if not, have a pro handle the job. That damper has to work just right to be safe.
    Consulting
