Another solid fuel boiler option
hot_rod
Member Posts: 28,263
I spotted this boiler at the Biomass Expo in Vermont this week.
Will be arriving soon, with listing approvals. Chips take a lot of the hassle out of burning. Pellets can come "unglued" after a lot of travel and handling. With a chip burner you could produce the fuel easily or have tree companies drop off a load.
This is the first quality, small size chip boiler I have seen. Marc Caluwe at Windhagerusa can get you some info
Nice. I've seen several, but not anything that was imported here http://www.windhager.com/int_en/products/wood-chip/purowin/0
Always amazed me how much shock their brains can take when doing that and they can still survive.0
Actually a,red headed wood pecker's brain takes a g force of 100 while pecking. I believe it was in Guinness book.0
Don't know if that is a pilated wood pecker or not. Here I saw one is a tree and there were so many chips falling to the ground you would have thought there was someone with a chain saw up there.0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
https://youtu.be/6OtgopNbrQg
