Estimate
Paul S_3
Member Posts: 1,291
I just left an air conditioning estimate in jersey city....and this how they braced the equipment....i guess they are digging down in basement for more ceiling height....i thought it was funny
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
347-692-4777
ASMHVACNYC.COM
Newest use for five gallon buckets. Check under the furnace0
Soft seismic strapsBob "hot rod" Rohr
Living the hydronic dream0 -
And home used to have steam heat its a brownstone...they converted to a "More" efficient warm air system 6 years ago ....compressor is case grounded probably from the poor installASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
The T&P vent doesn't look like it's 6" off the floor to me, more like 2".
Well.........when there was a floor under it.
LOL. We actually did that with my moms furnace when we had to pour a floor under it. Had it sitting on 2 x 4's which were sitting on five gallon buckets. Looked bad, but the furnace doesn't weigh much and we just had to pour a pad for a new base. We did take pictures, but not sure where they are.
Rick0 -
God help them if something goes wrong, the insurance adjuster will laugh himself right out the door.
3PSI gauge0 -
I think it's overkill. Surely the PVC venting would suspend it adequately. *eye roll*
Oy.Terry T
steam; proportioned minitube; trapless; jet pump return; vac vent. New Yorker CGS30C
What they said. If the pvc vent failed the water and gas lines would pick up the slack.0
- 114 Geothermal
