A step up from a tap a line
hot_rod
Member Posts: 26,587
from Cash Acme, a variety of sizes for ice maker and dishwashers.
Rated at 200F, 200 psi. I suppose a guy could use it to tap a small panel rad into a circuit.
Is that a "shark bite" variety?
I'd just use this and a copper tee.
Yes it is a SharkBite. I suspect it is aimed toward the DIY that wants a flameless installation.ChrisJ said:Is that a "shark bite" variety?
Still, many of the humidifiers ship with those crappy saddle valves, this is a nicer component, and it would work on pex also, saddle valves are not so comfortable on pex but we have all seen it tried.
Living the hydronic dream1 -
It depends on the saddle tap in question http://www.aymcdonald.com/en-US/Saddles.html0
Along with those stupid flexible drain connectors they sell at the home improvement stores?Robert O'Connor said:Self tapping Saddles aren't legal in NJ
It's Considered a Product that Violates the code
Robert O'Connor/NJ
If stuff automatically violates code it should be illegal for a store to sell it in the specific area. For example S traps.
