Propress/Baseboard
RJMCTAFO
Member Posts: 113
Found a couple threads from the past but no concrete answer. I am re piping a house that froze and putting in all new baseboard. Can I use press fittings on the thinner wall baseboard tubing? Anyone have a bad experience?
Have done many with zero problems.0
You can. No problems.0
Ive done them too numerous times with no problems. ....but i started to use these Viega inserts....ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
I use the inserts from viega with no problems.
Thanks guys. I will play it safe and grab the inserts.0
viega#16423 3/4 bronze insert
347-692-4777
ASMHVACNYC.COM
