Mixing Valve Control: Setpoint, Throttling Range, Integral, Derivative-What Does It All Mean?
VelvetFoot
I'm at a loss in setting up a Honeywell T775 analog controller for mixing boiler return water.
The literature that came with the controller seems to be more aimed at hot air systems vs boiler hot water. It came with a default of 20*F for throttling range, 400 seconds for integral time, and zero for derivative. It recommended keeping the range wide, emphasizing integral time, not messing with derivative.
Can anybody explain or point me to some literature on this?
Thanks.
Thanks.
http://www.csimn.com/CSI_pages/PIDforDummies.html does a decent job of explaining the concepts. The advice to stay away from the derivative coefficient is good. P & I will take care of most HVAC applications just fine.0
Thanks very much. So, after reading, I guess what I want to do is tune my PID loop. This knowledge will be easier to search on, anyway!0
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
